TwinTurbo.NET: Nissan 300ZX forum - If .045 boost jets (WAY smaller than inner hose diameter)...
Subject If .045 boost jets (WAY smaller than inner hose diameter)...
Posted by thumper300zx on August 01, 2004 at 10:58 PM
  This message has been viewed 213 times.
In Reply To well, that makes sense of course. but specifically, posted by robo (sebring1970) on July 30, 2004 at 09:38 AM
Message get you from 9/9.5 to 12.5-13 (3 lbs?) the inline adapters would probably give at most .25 lbs - if you get the same inner diameter coupler as the hose all you are doing is stretching the hose a bit to get it over and coming up with the same inner diameter...you might argue that there is a bit of a restriction based on a rough transition from hose to coupler, but it would be so negligible it wouldn't register as a change.
-Dave
